Well guys, i changed up my method from my first infusion. On the first one i sprayed spray glue into the mold to hold the carbon fiber down to the shape of the mold… bad move on my behalf.
This time after waxing the mold 10 times, waited 20 minutes inbetween coats. I then sprayed 3mils of PVA over that. The first layer of carbon fiber into the mold… i sprayed the cloth just ever so slightly even coverage, holding the can about 16 inches away from the cloth with spray glue, 3M #45 again. Also i infused about 25 minutes after applying the spray glue. It worked like a charm… awesome glossy smooth finish on the parts this time. Last time the parts had a lot of pourosity on the surface after they were pulled from the mold. Smooth as glass this time. Just some minor blemishes from the mold surface. The mold gel coat surface has some minor pin holes in it that the wax and pva did not fill in completely.
Overall, even though the infusion was a disaster, the parts actually came out looking decent. Just all dry around the edges of the part, and dry areas on the backside of the parts also.
Hey, I learned some cool stuff though.
3M #45 works great, just don’t let it sit for too long after spraying.
PVA and the spray glue are very compatible with each other.
PVA improved the surface finish of this part.
You can never have a perfect enough mold surface.
I love infusion
