pur resin in cold weather
The weather is so cold these days, and the part won’t cure correctly or taking days to get a full cure. Any of you experience this problem? what do you do to solve the problem.
Solution: Make the shop the correct temperature! At the very least keep one room closed with a SAFE heat source.
I keep the areas between 68-75* F. It’s preferable to carry out all work at room temp, as most material is made to be used that way. Spraying, tool prep, lay-up, curing, and bonding should all be done in the range of 65-85* F. The only thing that can really be done in cold or hot areas is trimming.
^^^ too true^^^
On a cold but sunny day, place the part in the mold outside in the sun light!
