large = ice cream or supermarket frozen products deep freeze
as far as i know, a normal home fridge pump can hold vacuum to infuse 3-4 sq. meters area… like 2 hoods !! every pump can achieve full vacuum, however flow is another thing. If your pump has higher flowrate, it can hold good vacuum even if you have a small hole somewhere.
by separate cooling i mean circuit. these pumps have usually 1 or 2 intakes, (suck) and one that blows.(yes if it has 2 intakes you can use them for multiple molds…if you dont use them both, you gotta clamp off the one that is not used) if the lubrication oil which is used for cooling too, is not on a separate circuit that the air, the blowing pipe may spit out oil (or smoke if the pump heats up) …this oil you should collect in a cup and put it in one of the sucking pipes, to suck it back in. That simple
