First off this site is outstanding - lots of bike projects…
Been messing around with composites for a year as a hobby, just starting to get through the confusion of v-ester / p-ester / epoxy compatibility which sucks.
Got good at making flat carbon / kevlar plates on glass & doing easy parts.
Stepping it up & working with 2part Urethane Pour Foam 4lb & Kleen Klay making shapes for plugs.
To avoid problems im just going to keep using epoxy products (USComposites) is my store so far.
Currently modifying my air induction system - working on the airbox now.
Used a 2 part Urethane pour foam to get a copy of the space.
As you can see its much larger than stock.
Going to keep one part of the stock box…
There are several ways to go from here but things are progressing.
