Im somewhat new to composites other than taking a course about them at my college. Im currently working on a project at work which entails bonding a piece of fiberglass backed PFA LT plastic to a 2.5" by 13" prepared mild steel substrate. I am working with many resins but the first im trying is a Vinyl Ester. The specific vinyl Ester is a Hydrex 100 along with a Superox 46747 MEKP catalyst. The ratio calls for 10 drops of catalyst per ounce resin. After mixing my resin and hardener I wet out the fiberglass, apply the metal sheet and proceed to vacuum bag it. The problem is not a mixing mistake as my leftover resin did cure. The problem I am encountering is that after the 24 cure period the part is still wet with resin and not cured. I have heard of people vacuum bagging Vinyl Esters so I am wondering why I may be encountering this problem. I had an idea it may because of the absence of oxygen but I am unsure, any help is appreciated.
Work Environment: 80-90 degrees Fahrenheit, Medium Humidity
Equipment: 3 cfm 1/3 horse power vacuum pump
Resin: Hydrex 100 Vinyl Ester Resin
Hardener/Catalyst: Superox 46747
Ratio: 10 drops hardener per ounce
A mil line is always within 3 lines of a bigger line.
