Well my latest problem is that my resin isn’t travelling fast enough/curing too soon, different sides of the same coin I guess.
I’m using VER catalyzed 1% mekp around 20 degrees celcius.
even with the red resin flow media (4 lavers of glass and some coated peel ply) the resin doesn’t seem to travel fast enough.
what should I do?
More flow channels?
Less catalyst?(but will is still cure?)
Different resin with lower viscosity?
suggestions?
despite this I still managed to get this nice undertail out of it:D ! but it was a pain in the ass cause I had to cut holes in the bag and then lay more strips of flowmedia and new resin tubes and then seal over all of it with mastic:mad: more work then I’d like to talk about and I would like to avoid such frustrations…
