Hi everyone
been lurking here for a while and finally decided to post about a problem I am having with a car I am building. I have some marine experience with composite work but only with the basic stuff, nothing like the high-tech work I have seen on this forum. All my work is done using basic hand-lay up with molds or moldless techniques and some cold-molded based stuff on the body. (yeah I know quite a variety
) I use mostly epoxy, west-marine or US composite.
After I finished the body I left it in the sun for a few days, sanded and painted a finish coat thinking that the print through was over with. Now I discover that the print through comes out when the sun shines on it and heats it past about 120* (it can get up to 170 sometimes), then disappears again when it cools down.
The body is highly finished with gloss black, the composite consists of layers of epoxy and cloth, with the top layer being epoxy mat and/or a surfacing veil with some thickened epoxy used as a fairing compound. That is then covered with duratec primer - 2 or 3 coats and a two-part polyurethane paint. As you can see in the photos the surface is flawless until the sun heats it up. The parts with the mat look a little like orange peel but the front fenders which are simply cloth with lots of fairing compond and duratec have the usual fabric print through look.
I have tried sanding down and recoating the duratec with no success I am hoping someone might have some suggestions that don’t involve remaking the part!
Thanks for any help.
I was hoping the close-ups would show the print through a little better. You can just see the mottled effect on what should be straight lines in the reflections.
