Hello guys,
i am wondering if anyone here who could help me out of buying some printed glass fiber surface mat with numbers from 1 to 100?
i would highly appreciated if someone dropping suggestions and ideas on this!
Cheers
Robert
    Hello guys,
Cheers
Robert
Robert, Are you needing these for component labeling for a series run? If so I’ve found that pre-cut vinyl letters or numbers applied to a thin fiberglass veil will survive infusion and can look quite nice.
Basically have all the numbers pre-cut with a local graphics guy who does decals etc. Then lay out a piece of glass cloth-(thin)……and place them in order as needed, then lay it al on a sheet of window glass and infuse. BAM !
Take a roll of thin glass matt or fabric, go to a printer shop and print the numbers on the fabric. Works fine with a solvent ink as long as you work with epoxy.
