I can rework some of the hard points to loose weight else where and also the thermal expansion would be down if stainless steel were used. Also for threading it is harder and less likely to be threaded incorrectly. Those are very good points that you guys mentioned. But the main reason aluminum was used was due to weight which is a major concern. Secondly aluminum is used due to cost, using stainless steel the price more than doubles for the pieces. So again would anodizing the pieces prevent galvanic corrosion from occuring. The metal parts are in a high risk area of coming in contact with fluids particuarly gasoline, oil, antifreeze, and water. Also the parts will have to stand up to a fair amount of abuse, so will the anodizing finish of a tendency to wear. So you understand some more the parts are being used as part of a carbon fiber intake manifold assembly. So I guess I will ask do you think that using stainless steel is a more attractive alternative to using the anodized aluminum pieces, cosidering price (steel is twice the cost), wear (how long will the anodizing finish last, I understand this depends on the grade), corrosion (the steel in contact with fluids etc, the aluminum if the anodized finish fails and galvanic corrosion takes place). The parts life span is around 20 years so again your opinion on what material/solution is best. Thanks for all of the advice guys.
Greg Scrivner
