Okay, I set it up, and tested it. (I had to remove the release valve as it was leaking from that area).
I then tested the vacuum pump for a 2nd time after the change. I ran it for about a minute the first time, and about 2 minutes the second, and I noticed something weird the second time. The vacuum pump started to smoke a little (brand new pump), and it looked like the oil was bubbling. I took a picture of that as well, return the pump for a new one? It did burn a little oil in those two minutes (atleast it seems like the oil level went down a tad), may be like a car though where you have to let it sit for a bit to get a correct level. Still though, the smoking seemed like an issue
Here is right after I saw it smoking, turned it off and took this picture of the oil view. It is a 2.5CFM pump, generic brand.
Any help guys? I saw a post about a smoking pump on here earlier, going to search it out but figure this may be something common?
**I have done a bit of looking around, and if this is just vacuum pump “exhaust” you can go ahead and call me an idiot.
I am not sure if it is burning any oil though, haven’t really ran it long enough to see, I know if its burning up quick theres an issue, hopefully not :x
