Hey guys,
So this is the first time I work with prepreg. I got some prepreg carbon fiber from Gurit. (the resin can be found here http://www.gurit.com/se-84lv.aspx)
The thing is this prepreg is really not very tacky, as in touching it bare hand at room temperature barely even feels sticky. Is this normal fro a prepreg? The videos i’ve seen seem to indicate a much higher level of tack. Is it possible the prepreg is no good?
This is proving to be quite problematic since it wont stick very well to the surface of the mould and hence slides around all the time during lay up.
Thanks!
