Hey everybody. I am new to the site and have been browsing for several days looking for information on this subject. I am making small parts for cosmetic use in automotive and motorcycle applications. I am wanting to make larger part eventually but want to hone myself with smaller things that cost less to screw up.
I have pretty poor working conditions as far as room temperature control. I work in an non insulated work shop, which means I have only a few weeks of good temps. The rest of the time my resin does not cure due to low temps or it cures while in the middle of an infusion, even when using very slow cure catalyst (120 min). I am wanting to find a catalyst that I can use with epoxy resins, both for infusion and possibly for some small batches of home made prepreg material.
My reasoning is this: I can spend HUGE amounts of money insulating, adding heating/cooling units and so forth in a work area that is hardly worth the time or money, or, I can put a small amount of that money toward building a smaller more easily heated “oven” and the appropriate temp control setup. The latter I think I have figured out.
I realize that prepreg material is readily available, but I am really interested in using carbon/kevlar and carbon/fiberglass for the color options. I have never ran across either of these materials in prepreg form. I do not know if I will ever need enough to special order anything like this.
I think that maybe I have already stumbled across these resin catalysts and or systems but might not know the appropriate wording and not know exactly what I was looking at, so if I have overlooked things I apologize.
The only other question I have regarding this topic(I am full of questions of course), is more of a curious thing that occurred during my first VIP. My shop temp dropped to appr. 40 degrees after infusion but before my resin passed B stage. After 2 days my part had not set. At this point I figured my part was a failure so I began playing around. Eventually I tossed it in the oven and cooked it for about 30 minutes at 150*F. Stupid thing cured and life went on. I realize this is not the correct method, but it got me wondering if a slow cure epoxy (120 min) was laid out in prepreg form, kind of like the video from david algie, and then frozen before passing B stage, to stall the cure. Then cured in an oven, would this actually work like I need? The part I ended up with is very rigid and looks like other carbon I have seen completed.
Thank in advance for any help and for reading my long winded ramblings
steve
