So I will be making my first “on my own” part in the next month or so. I am fortunate enough to have access to prepreg carbon fiber which I plan on using for this project. The part itself is used to protect a battery from rocks and debris with little to no structural strength requirements. I plan on doing 3-4 layers for this project.
Attached is a PDF file of the part I am trying to make and the outer surface is the visual side. (Look at it upside down and I will be laying up inside that theoretically).
I have a couple of ideas for the mold, but am open to suggestions/recommendations as I have very little experience with composite materials.
1st. Make a wood plug of the part and layup over top with fiberglass to make a mold. I was told if I need to do this, I would need to “reinforce” it (Not sure if I understand 100% what he meant), I am thinking it means use thick matt on the back to add more rigidity?
2nd. Mount 3 pieces of rectangular tubing to a plate and fill (form a radius) at the base with some sort of filler that can handle the autoclave temperatures.
3rd. Split the design into 3 pieces and form them out of sheet metal, and screw them to a plate trying to match up the edges so no seam is shown.
Thanks for any input guys.
Edit: By the way, only a single part is required from this, however I am under the assumption that I may need to redo it a couple of times as it is my first time doing it alone.
