I’ve run across a bit of a problem with a project I’m trying to finish up.
It’s a speakerbox, and a very complex one. I’m building it to be as light as possible. Foam core (lowes, the blue stuff) epoxy resin, and 7oz (6k series?) glass cloth.
The baffle if already done, and cut to it’s proper shape. Between the speaker and the baffle is a spacing ring, also made of the foam sandwich.
The Speaker weight is minimal, at around 5lbs. It’s a 12 inch lightweight neo driver.
I need to figure a way to mount the speaker to this baffle. I’m thinking t-nuts potted in with epoxy/milled fibre. I’m just concerned about them pulling through under all the weight and the cabinet itself being bounced around in transit.
Any ideas?
