When post curing an epoxy laminate do you always do so with the part still in the mold?
I’m thinking vacuum infusion or wet lay up/vacuum bagged… popping the part out of the mold, THEN placing it in the oven to post cure This would be done after an initial 24hr room temp cure with part still in the mold and vacuum bag.
This all assumes I can find the right epoxy.
It’s good for me to know this stuff and learn. I understand many parts are V.I.P.'d and it seems some would need a post cure if not being done in an autoclave?
