Hi Guys - I’ve been lurking and learning from you experts for a while now, so I thought I’d throw out a quick question. Should be an easy answer, but I can’t seem to get a reply from Pro-Set.
Anyway, after an infusion has reached “Stage B” cure (Maximum cure at room temperature), it must be brought to final cure via elevated temperature. No problem there - the question is the time between Stage B and the elevated temperature cure.
Is there a window, or not?
i.e. Do I have 24hrs after stage B is reached, or 24 days - maybe even 24 weeks…??
The reason I’m asking is that I plan on making several small parts and doing the final cure in larger batches. So some parts may be sitting around for a few weeks, while others might have just hit “Stage B”. I’ve looked through Pro-Set documentation, but I’m a guy… so, it’s probably right in front of me and I can’t see it!
:cheesy:
Anyway, thanks for your time and input!
Best Regards,
Dallas
