Using polyester resin (even with vinyl ester epoxy resin) I need to make thick pours. Is it possible to accelerate the time it takes to shrink and the majority of the outgassing after it has cured?
Right now i make it cure as slow as possible so heat doesn’t hurt the expansion so much. Is this correct?
I have many successful pieces, but I’m letting it set for about 2 months before I do any finishing work. Half-millimeters are like the grand canyon regarding “size” on this piece. I am hoping to reduce this amount of time.
T.I.A.
