Hi, was wondering if anyone has any suggestions regarding the repair of the back of a mold tool which was made out-of-autoclave. The tool is porous throughout and there is was little vacuum integrity when surface bagged. I have coated underside with epoxy resin to try and seal and this has helped me achieve a higher vacuum pressure but still it wont hold vacuum? An envelope bag is out of the question due to the complexity of the underside ( contains rib structure).
I have considered wet lay-up of dry glass underneath but not sure if this will be sufficient or if there is a quicker, cheaper and less labor intensive alternative? I need to re-use tool multiple times and cannot afford to scrap and start again.
The tool loses vacuum pressure in line with temperature ramp ups so thermal expansion is playing its part in aiding the loss of pressure which suggests porosity is still inherent.
