REFER PICTURES
Type of Material
Carbon 922-1 TENAX HTA (Carbon Graphite), FM300 Surfacing Film
Type of Material (Mould)
Steel
Bagging Sequence
Laminate > Solid release film > breather Ultraweave > bagging film
Curing recipe (Autoclave Cure)
1.Apply full vacuum (22 inHg @ 74.5kPag minimum).
2.Apply pressure to 500±10 kPag (72.52±1.45 psig) and begin heat up.
3.Vent vacuum to the atmosphere as a part of the pressure cure cycle, when the autoclave pressure is between 103.42 kPag – 137.89 kPag (15 – 20 psig).
4.Heat up to 179±5°C at a rate of 2±0.5°C/min. Heat ramp rates only apply when lagging thermocouple achieve 48.88°C (120°F). Heat ramp shall be between 25-225 minutes.
5.Dwell for 120 – 300 minutes at 179±5°C. Dwell temperature is achieved when lagging temperature achieve minimum dwell temperature (minimum 173.8°C).
6.Cool down at a rate 2±0.5°C/min.
7.Release pressure when the lagging thermocouple decreases to 65.6°C (150°F).
PLEASE HELP ME ON THIS. HOW TO ELIMINATE THIS POROUS SURFACE ON CURVATURE
