I’ve done virtually all my composites work over the years with epoxy based products; tooling epoxy mold surfaces, epoxy laminating resins and woven reinforcements. So I have a project on the bench that has no structural requirements, is fairly large surface area (compared to what I typically encounter) and would be well served being infused with a clear finish already applied in the mold surface. Since I didn’t need high accuracy in the mold or subsequent parts, I figured an inexpensive tooling gelcoat, polyester tooling laminating resin and woven+chopped strand glass would be sufficient. For the parts, I planned on clear gelcoat, polyester laminating resin and a variety of reinforcing fibers (infusion after the gelcoat set).
Mold construction went OK, but spraying the tooling gelcoat cost me an old/cheap HVLP gun as even catalyzed at the low end of the recommended range, it kicked before I could get the gun cleaned. So that pissed me off a bit, but I used a junk gun figuring this might happen.
Moving to part construction. The clear gelcoat from US composites is like a can of peanut butter. So I catalyzed it at the low end, thinned it with Styrene, and after about 4 minutes of very poor spray performance through one of my favorite HVLP guns, it started to set; quickly. I rushed to clean the gun and I’ll hopefully be able to salvage it.
So now, with a thin/incomplete layer of gelcoat in the mold, I ran to Harbor Freight for a couple cheap HVLP guns. Second batch of clear gelcoat was expected to be sacrificial over what was already in the mold. Sprayed a bit better with the HF gun, but after about 10 minutes; BAM, another gun headed for the trash barrel.
In all the years I’ve been working with composites, I’ve always fabricated my laminates with epoxy based products, then cleared them; generally with DuPont automotive clear. At this point I’m so pissed about the lack of control with some of these polyester based products, that I’m tempted to box up every bit I have and take them to the dump.
While I’m sure it will be pointed out that these challenges are more about my process and lack of expertise with these materials, it’s still frustrating that the chemistry has this many variables. I don’t like the idea that cure time is variable based on catalyst amount, and the volumes used are too small to be controlled with high enough accuracy to guarantee cure times. Give me epoxy any day over this stuff. Component quantities large enough enough to measure, the exact same ratio every time, small variation in gel time based only on ambient temps and surface to mass ratio in the container.
Sorry for wasting your time with my rant
