I’m new to plug making but i’ve been a GRP repairer in the marine industry for 7 years.
My first plug, is a bit of a big project tbh for my first plug, it is a car door. I’ve been using all polyester composites as this is what I know. I’ve made the plug now, it has turned out ok, but it was slightly difficult to release, but no damage to it so fairly happy. My plan is to make the final door in epoxy, But I have some questions.
Have I made a mistake making my plug from polyester? I keep reading about shrinking issues and I can’t really have this with a door.
Will I have problems with a poly plug and an epoxy mould?
Is epoxy compatible poly gel coat any good? Is this the best route for me as I will be painting the final door.
For plugs that I am not overly bothered about with the finish, is there a cheap suitable solution rather than spraying and rubbing down as the expenses add up doing it this way. I’ve seen a guy on youtube using a varnish,is this really a suitable way? I would like to brush on to if poss. What have you guys used?
