Hey guys,
I have a plug i’m making from an existing part. The existing part has a fine textured surface to it and is made of abs plastic. I am thinking of mixing up a fairing compound with epoxy, applying it just enough to fill in the texture, then sanding it smooth.
I bought some Rust-oleum automotive primer in aerosol cans. The can says “Fast Drying”. How long after i primer the plug do you think i should wait to do the mold lay up? I will be using epoxy based mold resin. The temp outdoors is like 55F but i’ll be putting the plug indoors in 72F after a few hours of initial drying time.
