As you know I’m busy with a mold for a VW rabbit hood. Now the outside mold is finished and it’s time to move on to the inner part (ribbing side). Must I make a mold impression of the inside looking exactly like the OEM part? I guess I have to, because all the mounting point for the hinges and latch are on the existing ribbing. And if the inside is off by a hair thickness then the carbon part will have uneven panel gaps.
Now ribbing of the OEM steel hood is partially spot welded and the rest is bonded with a type of putty to the outer skin. That means the ribbing part is elevated by about a half a inch from the outer skin. I’m planning to tape these panel gaps with masking tape sealing off any gaps for gel coat bleeding, and then layer it with FB.
This hood has rolled edges, but it’s rolled in a square fashion. I believe it’s going to be in my way when the flanges are glued onto the outer side, for mold preparation. Is it a good idea to cut them flush with the outer side of the plug?
Remember the mold for the outer part still has them, so the final outer carbon piece will have them.
Here is a pathetic drawing of what I’m trying to illustrate.
