I’m making a plug for a carbon fiber headlight delete panel for a Mazda RX-7 autocross car. Its my personal car, and my second composites project. Last winter I made a carbon fiber sunroof delete panel, which saved 20 lbs and looks great.
Where is what I’m planning so far. I made a wood base box, which includes an angled surface. The angled surface matches the mounting surface which I’ll attach the headlight delete panel to. I plan to mounting the factory headlight cover (has pop-up lights) to the wood base panel, at very specific distances from the base panel. This will set the height of the delete panel and thus ensure alignment with the hood, fenders, and bumper when installed.
So I’ve done quite a bit of measuring, and have all the angles, and distances that I need to set. I’ve got some pictures which show the cover panel setup where it needs to be.
Pics:
IMG_7416.jpg by Kevin_Doe, on Flickr
IMG_7418.jpg by Kevin_Doe, on Flickr
IMG_7419.jpg by Kevin_Doe, on Flickr
The sides needs to be filled in, so I can make a mold from this plug. So here is my question. How would you attach the cover panel to the wood base, and hold exacting dimensions? Then, what would you use to fill in the sides. The mounting needs to be rigid enough to withstand some shaping of the sides, and sanding to make the plug look very nice.
I’ve thought of hot glue and several dowels but that seems like it would be difficult to get the dimension right and wouldn’t be rigid enough to hold it in place while I’m filling in the sides and sanding.
I’ve thought that tooling dough may be nice. I could build up quite a bit of the tooling dough and then press the headlight cover panel down into the dough until I’ve got the dimensions and angles correct. Then shave/scuplt the overflow down to get the side “walls” correct, then let sit till cure. I’ve never worked with tooling dough. Will it be thick enough to hold shape w/o sagging or “flowing” till it’s cured? Any thoughts about this idea?
I’m looking for some ideas, so please let me know your thoughts.
Thanks!
