Not exactly sure what you are trying to accomplish with paper towels and epoxy? I HAD thought that you were wanting a way to seal that end so you could make a mould from the whole thing?
If so, there’s a plethora of easier ways to do it than with paper towels and resin! The simplest would be to just cover the cardboard with polyethylene packaging tape. Or replace your cardboard semi-circle with some core flute. However, have you made that end a straight 90 degrees? If so, you are going to struggle with the draft angle when it comes to release. If that end is going to be cut out of your final parts, I suggest angling it or building it up with wax/plasticine/clay so that you have a positive draft. Even better would be to leave it out of the mould completely by building your flange vertically on that side.
But I may be getting ahead of myself with my advice given I am still struggling to understand what you are trying to achieve…
