Hi!
I’m making this thread because I need some help choosing an epoxy. Based on old threads from the forum, I’ve gathered that you can’t expect to get a Tg of above 200F without doing a post cure - that’s fine though. A Tg approaching 200F will do great for me, especially if it means I don’t need to bake it and I can demold the part within 24 hours at room temperature. I was using a polyester before (S249) but can’t anymore because of the fumes, and more importantly, because I was getting pretty serious print through. So I’d like to switch to an epoxy!
What I’m doing. I’m making a part that will be exposed to the temperature of the interior of a car. So it can get pretty hot in a bad situation, but not much above 150F. I’d like to also be able to do an in mold coating spray of clear, so if you can recommend an epoxy compatible with a urethane clear (or maybe that Sherwin Williams product that so many appear to be a fan of) that’d be great.
Anyways, here is what I’ve come up with. Let me know what you think of them if you’ve used them before. If you have recommendations or favorites that I haven’t listed, PLEASE let me know and it’d also be great to know where you buy them from. I understand that at this premium grade of epoxies large orders are necessary, but that might be alright in my case.
Note that I’m using these with carbon fiber and cosmetics are very important, so I need something that is as close to clear as possible.
Huntsman Ardalite 8601 or 8602 - RT cure and a Tg of 164. Not great, but better than the US Composites 635 that I’d currently have to rely on. I understand that their higher 860x products have better Tgs with a cure schedule, I think I saw one that can sustain high temps with just a 150F cure.
Freeman 690 - the tech specs said Deflection temperature is 180F - not really sure what a deflection temperature is, can someone clear that up for me?
Adtech or Cass? EL-300 - Deflection temp (again, ?) of 232F. They say it’s a “clear light amber” but I guess that’s just their way of saying it’s not polyester clear but still pretty clear, or at least hopefully that’s what they mean. Any recs on their EL350 and EL360 are also welcome
Gurit Ampreg 21 - Looks fantastic, but of course it wouldn’t be available in the US -__- , or at least I couldn’t find any after a quick google search. If yall know where to find some please let me know. So really, if there is anything comparable to this available stateside, that’d be great!
Finally, I couldn’t find the tech specs on Miapoxy 100, does that have a good Tg?
Thanks in advance for the help!
Chetan
Edit: forgot to mention, ‘strength’ isn’t a primary requirement. While it’s great to have, the characteristics I listed above are more important to me.
I guess I’ll look into building an oven. I called the Gurit US offices and one of their reps recommended the SP115. TG of 150F after 4 weeks with RT cure, that goes up to 183F with a 50C 16 hour cure. So a low temp oven cure which should be doable with a room size enclosure and simple heating elements. I think I’m going to order about a gallon of it to try it out directly from them. It’s about $130 US for a gallon.
Don’t know about the UV resistance, but my experience with those kind of “surf” resins is that they will yellow anyway(on the outside parts of cars).
