plans for a carbon fiber longboard
should 11 layers be able to support up to 250 lbs? or should i put in layers of wood that i used for other longboards as well?
my main concern is the board cracking down the road. any suggestions before i start this project?
anyone?
11 layers is a bit excessive. Normally they’re made with a couple of layers with either a foam or wood sandwich core.
yea i was planning to add layers of fiberglass and wood, but the majority of the layers will be carbon fiber, especially the top and bottom layers.
you wouldn’t happen to know from the top of your head how many lbs one layer of cf can handle do you?
That depends on the resin you use
