How can one go about creating a mold like this?
[ame=“http://www.youtube.com/watch?v=1ssRTWF0nt0”]YouTube - resin infusion[/ame]
I always thought about taking any mold here, making a thick fiberglass part with a full flange, not trimming the flange, and using that as the upper portion of the mold. The idea would be then to take that new part , add on a rubber gasket to the edges, and then tap in holes for the vacuum and resin lines. The idea would be to turn a mold which would require a vacuum bag for compression, into a double sided mold where you would achieve perfect vacuum in a matter of seconds.
I basically would like to be able to reuse the same bag, (or in this case a molded back form) to be able to 1. Save money in the long run on materials, and 2. save time on setup.
In this case with this violin mold, I see they put resin grooves so that way they do not have to use flow media. That then would save on the cost and time of purchasing / adding flow media as well.
Any ideas?
