Hi guys,
Does anyone have any charts describing much strength is lost when a typical carbon fiber/epoxy laminate has its fibers oriented at varying degrees from the load? Like, if a UD laminate’s fibers were 5 degrees off axis, or 45 degrees off. Or a woven laminate that’s 45 degrees off? In my own testing, a 2x2 twill weave was about 63% as stiff in the 45 degree angle than at 90 degrees, but I didn’t exactly use a very sophisticated setup
Also, what’s the theory on the failure of these laminates? Will the fibers reach their ultimate strengths, or will the epoxy experience shear failure before that happens, or will the fibers themselves experience micro-shear failure due to carbon fiber’s extremely low shear strength to tensile strength ratio?
I have read somewhere that a UD laminate that’s only 5 degrees off axis will lose 50% of its stiffness and strength. But wouldn’t it depend on the aspect ratio of the laminate too - assuming the epoxy would fail in interlaminar shear? Or are the carbon fibers themselves inherently 50% weaker when they’re 5 degrees off axis?
Thanks.
-Gene
