Old post, but thought I’d add my 2 cents away. In case it helps someone.
That thin polyester peel ply by Airtech and sold by fiberglass supply, is nothing more than polyester (kitesurfing and sail fabric) taken from the mill, untreated and raw.
How it pulls off has nothing to do with the quality. Polyester is the clear plastic material in your water bottles. This peel ply is the exact same polyester, woven into a cloth. So it naturally has zero stick to epoxy. That’s what I like. No treatments are added to the fabric.
The force to pull off, is directly related to the amount of resin squeezed through the fabric by your vacuum pressure. This is a good thing for some applications. You want to squeeze out excess resin. Lighter parts.
Don’t use polyester peel ply if you don’t like the force to tear off. Use other types of peel ply. Or, reduce the amount of resin saturation before bagging, so the peel ply doesn’t have to expel so much resin.
