I might try to tape the edges down and sand. It’s too large for our sandblaster, and I got VERY strange results in my peel tests.
I did 2 panels, one with the peelply only skin, and the other was the sandblasted. I did the FLoating Roller peel.
Layup was S2 skin, adhesive polymer layer (prob’ can’t say WHAT), and then the base substrate.
While each sample was about the same peel strength, and the adhesive pulled from the substrate…on the peelply surface, I actually had lifting of the adhesive layer from the S2 skin in certain areas…
So the peelply surface was the weaker one, even though it failed on the substrate side.
