Again to the debate of polyester gelcoat - epoxy resin in a laminate. I have read two very popular composites books and it seems that the authors have different opinions on this matter. More particularly:
Book #1:
“Epoxy gelcoats are available, but nobody seems to produce a clear epoxy gel. However, if you wish to make a clear matrix component there are a number of options open to you…
Or you could use a polyester gelcoat. Again, most people will tell you that this doesn’t work but providing you allow the polyester gel to cure well past the “still tacky” stage, epoxy resin will then adhere to it (extremely well) and cure properly.”
Book #2:
“The interaction between the epoxy used for laminating and the air-inhibited tacky surface of a polyester gelcoat is unpredictable-some formulations inhibit the cure of the epoxy, and manufacturers and formulators of both epoxy and polyester resins can generally offer no advice beyond “try it and see”. When i tried it, with a fairly common polyester gel coat and an even more common epoxy laminating resin, what i saw was not a happy sight. Despite leaving the gelcoat to cure for an extra long time and although both the gelcoat and the epoxy seemed fully cured, between them-right at the plane where the two met-was a thin, sticky layer of uncured something-or-other. With little effort, the gelcoat peeled off, like the shell off a boiled egg.”
So, what’s your own opinion on the compatibility between polyester gelcoat and epoxy resin?
