Good day,
I have a couple quick questions. I have a few plastic bits on my honda motorcycle I want done in a carbon/kevlar hybrid. Is it possible to make the parts 1:1 (ie) scuff the plastic, lay the cloth and resin and then clear coat?
If this cannot be done, what is the proper technique for recessed mounting holes. Please see the pic below… the two bolt holes are recessed, how do I go about laying the cloth in these areas to maintain strengh and beauty?
They sell Carbon covers for the Ram Air snouts that just cover the outer exposed surface. They attach with 3m double sided tape, i sthis method common?
Also, the plastic has a surface that is slightly ruff. Will preping with 400 grit and working up to say a 1200 wet be sufficent for making a tool or will I need to get it glossy? I plan to clear the part for uv protection and beauty…
Thanks again,
Jonathan
Great all that and I cant attach a pic…[/img]
