been here for a while, wanted to show you all my test panel
Resin infusion, spreadtow fabric, aramid fabric, 2 layers total, size 1,2m x 1m
Big test panel! what are you going to do with it?
CHESS BOARD
It is a shame the aramide shines through. Nice panel, though.
I know it is big, but in the past I´ve made one the same size with a resin with higher viscosity from Rampf. No success. Thinking about it, I also changed the feed tube arrangement, so I can´t compare one to one. The resin stopped flowing half way.
With this plate I was using Sicomin resin SR 8100 with the 4h hardener. But I´m super satisfied how well the resin is working. I did not cover all of the fabric with distribution mesh, stopped 10cm in front of the vacuum line. The resin is so thin that it went through the two layers and peel ply without problems, of course a lot slower.
I might use it for the Formula Student project at my university. Then it will be waterjet cutted and used as close out plates in the our space frame.
yeah, I know, but is was for test purposes.
