I noticed now from having a small composites shop, paint contamination is a problem when working with composites supplies.
I used to wax my molds with NC770. I can tell you if you spray (aerosol) this stuff one time in the same shop you do your paintwork in… fisheye city!
Any mold release products that contain PTFE or silicone will adversely react to paint and clear coat work.
Wax your mold with silicone or PTFE products - Expect a bad, fish-eyed paint job on that part. Especially if your part surface is not perfectly smooth, has voids in the resin on the part surface. In these voids is mold release that doesn’t wash off and paint or clear coat won’t stick to.
Using a vacuum pump that releases smoke and oil into the air? Yep that will contaminate your clean part surface prior to a paint job.
What do you do then?
Set up a paint booth or seperate room for paint work. Clean and prep your parts inside the booth.
Wash your parts with dishsoap and water prior to painting. Rinse with water. Wipe with a clean white cloth. White cloths do not contain dye that will wipe off on the part. Let dry completely.
Use a solvent based wax and grease remover made for paint prep work - follow their directions for use.
Keep your painting rags out of your work shop where they can get contaminated. Use only white rags or the blue shop towell rolls for paint work. Scotch brand works very well for the blue towells.
Keep your mitts off the cleaned part… your hands have natural oils on them that can cause fish eyes.
Don’t store paint chemicals beside other chemcials. Someone touches the cans of paint with dirty oily hands, you go to mix your paint and then touch that same can and viola… contamination transfers onto your work.
clean your spray gun with gun cleaner or equivalent solvent, store the gun in a clean place.
Clean your spray room/booth regularly. Paint shops sell plastic on rolls that sticks to the walls of your booth… it gets dirty you simply tear it off and throw it away.
Buy an air hose for paint work only. Don’t use it for anything else but painting.
No automatic oilers on air compressor lines.
Install a water and oil filter on your air compressor line. If you can’t then buy a $9 disposable ball filter for your paint gun… it will last for a couple uses.
new paint guns sometimes have oil inside them… clean them prior to first use with solvent. Acetone works well or gun cleaner.
Lightly tack cloth the part prior to paint and after the part has been cleaned with wax and grease remover.
mold releases that contain silicone … silicone contamination won’t clean off with anything I have found. semi perms some have silicone in them or PTFE. Paint hates that stuff.
Hopefully this is helpful info.
