OVERLAY problem
1st time ever
i be usin a 1:1 epoxy cleer laminating resin.
the problem… its over 3 weeks and the part is still like tacky… obviously i mixed the resins badly fo sho.
Can it possible be to place another peice of carbon fiber over the part if its still tacky? and re do process correctly?
suggestions please
Yes or sitck it out in the sun or a heated source first to see if it dries better.
i have had it in the sun,.,.,.,…
i might have gave it to much heat. Is that possible?.. i was using a strippers heat gun… so it got like wicked hot… i don’t knwo thoug…
i will try some hair dryier and see whats up… is it could be a possibility that the resins are bad?
Epoxies can last long than PER and you can freeze either for long shelf life too.
PER: (whats this)
poly ester resin = PER
http://www.compositeforum.werksberg.com/showthread.php?t=1345
thanks :o i figured thats what it was just making sure…
