I am looking at overlaying some interior car parts that are made from brushed aluminium…im guessing this isnt going to be possible??
thanks
If you first apply an epoxy coating over the alu and lett it cure there won’t be much problems.
And scuff the ali really well with 60 grit.
Scuff the aluminum and clean with acetone immediately before applying epoxy. Keep in mind if you are using carbon, it will react with the aluminum and corrode. 1 layer of fiberglass between the aluminum and carbon (if using any) will reduce the corrosion potential.
