Okay,
This last weekend I did some overlay work with silver tex and some clear poly surfboard resin.
Here is what I found out about overlays…THEY SUCK!
Really, had the subwoofer boxes been less compound curved and I had some way to lock the fabric agains the box without problems Id like doing them.
So now I want to know…WHAT GLUE CAN I USE TO HOLD THE CLOTH DOWN EVEN WHEN I START USING THE RESIN?
For me, I tried one using a light coat of resin that got tacky…I waited another hour and tried to use more resin. That just let up the cloth (solvents loosened it up?) and I was fighting air bubbles.
Then After a failure I redid the second box and used 3M super 77 which using the finger tack test, was much stickier than the infuzene I have…but as I suspected the resin let the cloth loose from the glue.
THERE HAS TO BE A GLUE THAT HOLDS…anyone want to help me out here?
