Overlaid/Wrapping over Holes
I trying to wrap some interior pieces but, the have mounting holes to re-attach them, how do I go about wrapped something and still being able to use the holes.
mejor, en englais…
and how about some pics… i’m just not seeing it.
Correct me if I am wrong as my Spanish is a little rusty, but doesn’t that mean “my wife or woman”?
no, woman is mujer. mejor = better. as in, better in english. Yes your spanish is rusty. pero te puedo ayudar si quieres.
Just redrill the holes when all is said and done. You’re only covering one side, right? If so you can just use the back side of the part for reference as to where to drill the holes. If you are going to be completely covering the holes, front and back, then try to recess the fabric down into the holes so as to leave a noticeable reference where to drill the new holes. Just take care when drilling not to crack the resin.
What would be the best type of drill bits to use and if I crack the resin will I have to redo the whole wet layup, or just redo do the crack. Could I drill holes prior to building up my layers of resin.
