ordering list. Am i missing anything?
Just wandering if you can spot if im missing anything?
Mould
Gelcoat + pigment
fibreglass (csm)
poly resin + hardner
Part
Topcoat
carbonfibre
Expoxy resin + hardener
The only reason im asking this is because im unsure about the gelcoat and topcoat.
gelcoat is the stuff thats meant to be on the mould and the topcoat is the finish layer on the part (right?)
Im pretty sure im right but just thought id double check (please shoot me down and jump on me if im wrong, i need to know because of ordering more stuff today - well 7 hours time)
cheers
mike
(ps where is everyone its gone really quite on here)
make sure you have some sort of mold release agent… pva and wax or the semi permanent mold release
Thanks your a star (should have said id got those from the last lot - my fault sorry - I didnt order all this stuff last time so ive got nothing previous to go by)
i take it from your answer that i was right about the gelcoat and topcoat, or would you use something else.
cheers mike
yup, looks good
you will need some kind of filler for the edges when you are building the mold,as seen here- http://www.cstsales.com/HTFiberglassMold.htm
The top coat is a clear or pigmented gel coat that you scray into the mold first.
The gel used for the mold is a tooling gel or you can use other casting resins also.
listed in order of use
mold
release agent
tooling gel (i use black)
fiberglass filler
fiberglass cloth
resin
fiberglass mat
resin
fiberglass cloth
resin
fiberglass filler
part
release agent
clear gel
carbon
resin
fiberglass
pull part then finish with topcoat.
Well done you guys!! You eased me worries and helped in one go
no need to help a grannie across the road today youve done your good deed today :roll: (i dont half come out with some cr#p lol)
I owe you all (not sure what lol)
Got a busy day ahead so will catch later!!!
ThAnK YoU
Dan’s list seems to be complete, thanks Dan
