I’ve been messing with making some moulds. I’m going to list what issues I’ve had with each and what I learned.
All these processes have used at least 3x coats of dolphin wax and pva
First mould was of a small plastic tray. I poured the orange tooling gel on and it was extremely thick in some spots. In the end the item melted underneath because I think I either over catalyzed or just put to thick a coat on. I did not have lifting issues with my tooling gel and I wiped my pva on with a rag
Second mould was a larger tray. I sprayed my pva on with a hvlp gun, I put about 2 heavy coats on. After that I put my orange tooling gel on but not nearly as thick. after my tooling gel cured I had lifting issues on my flat surfaces. I fixed this by vacuum bagging my first two layers of csm.
My third mould was a bracket. Besides for it getting channel lock, I had the same issue with the flanges and flat surface spans lifting up before I can reinforce them.
I work in a 70 degree room that sometimes drops to around 60f. I put my chop strand mat on 2 layers at a time sometimes but this seems to be an issue before I even get the chance to overheat with those layers with poly resin.
Anyone else have this issue of your orange tooling gel lifting off your part? I’m thinking either I’m putting to much pva on, or I just need to wax less so there’s less release. It generally happens on flat surfaces and the only reason I ask is because I’m making a mould of a semi flat panel in the next few days.
