Optimum braid type for bending stress in square tube?
Hi, I am new to the forum, and carbon fiber. I wish to make my own square tube, about 3/4" x 3/4" and very light. I have a reasonable understanding of the principles that underlie fiber orientation and how it affects strength characteristics in various directions, but I am uncertain about specific terminology or how to go about asking suppliers for exactly what I want.
In short, virtually all of my stresses will be in bending, and thus I want a braid (some sources call it tube) that is mostly unidirectional, but with some hoop strength. Exactly what kind of braid or weave should I be asking suppliers for? And is there any supplier that specializes in this particular kind of braid?
Edit: I would imagine I could use two layers, a unidirectional and a regular braid for hoop strength, but for simplicity and weight, I really want only one layer, of an optimum braid for bending strength.
Basicly you want +/-45 on the sides, and unis on top and bottom.
The first is simple, these are standard braids. The second is a bit more complicated, I would revert to unidirectional tapes, not braids.
The nice thing is you can bury the unis in a couple of layers of braid, so you get some stability for the unis in compression.
Thanks for the reply. Admittedly, I did not clarify that the bending stress may come from any side, so the uni would have to be on all four sides. I was really hoping for a braid that could do both things in one step, in effect, a braid that is comprised mostly of unidirectional fibers in the warp direction (I hope warp and weft are applicable terms for braids and tape :))
If such is not possible, what do you think about a uni tape 3.5" wide, wrapped around the mandrel with aproximately .5" overlap, and then a lightweight braid over top?
I would prefer braid-uni-braid. This keeps the uni in column better. (although most tubes indeed have uni on the inside, so it might not be a problem)
Due to the nature of a braid it is impossible to effectively introduce a uni into that. So you will have to live with separate materials, or have the mandrel overbraided.
Thanks. What exactly do you mean by “have the mandrel overbraided”? can you explain this phrase?
[ame=“http://www.youtube.com/watch?v=j19na8LMBnE”]Giant 3D loom weaves parts for supercar - YouTube[/ame]
