Recent customers have been giving me some decently small highly detailed pieces to make in small production runs (5-15pc). I really enjoy infusion as my final part quality is just fantastic and flawless, but with these new pieces… I need the fiber to hold in the details as I work around the corners and edges.
A friend of mine gave me a can of Airtac 2 and told me it will make the detailed job really easy as the adhesive holds the fibers inplace as if I were doing the piece pre-preg.
The problem I’ve found is that I wax season the mold, then PVA (just like I always have). The adhesive works great, but as I manipulate the carbon into the details, the adhesive sticks to the PVA and pulls it off the mold.
My thoughts:
Use more adhesive (not just a light mist)
-Pro’s? The adhesive will stay wet longer as I lay the fiber
-Con’s? I don’t want to use too much adhesive which may alter the aesthetics of the final composite piece -
Ditch the adhesive and hope for the best
-Pro’s? PVA untouched
-Con’s? Scrapped parts if I can’t get the fiber enough into the tight corners durring bagging -
Ditch the PVA
-Pro’s? I can manipulate the carbon all I want with out pulling the PVA off
-Con’s? I absolutely can’t have a part stick and PVA is my security blanket in that regard
Would a wet layup be better maybe?
Any and all thoughts, suggestions, and comments welcome.
-C
There are so many mold surface, release, resin, in-mold-coating combinations out there that everything should be tested. Not every combination plays nicely together. Change any one variable and you can go from success to failure. TEST! TEST! TEST!
