im trying to make some cosmetic parts for my car. and im using wet lay-up method since im bearly starting. now when the part its done. i lay it out under the sun to test if the resin would hold up and within 5 mins of been out there the parts goes soft. ive tried www.fiberglasssupply.com’s Clear Coat and SB112 UV Clear Epoxies and no luck. any suggestions??
what kind of epoxy do you all use?
