Hi there,
so, today I’ve started playing around with the vacuum pump kit that I recieved yesterday.
The problem… by accident I got oil in the exhaust fitting of the pump. So I just managed to get it out again, and pour it in the oil fill port.
Following the directions from the pump manual, to test it, I do as follow:
[ol]
[li]remove plug from the exhaust fitting[/li][li]remove the cap from the inlet fitting[/li][li]turn on the pump[/li][li]once the pump runs smoothly (2 - 30 secs as per instructions), place back the cap on the inlet fitting[/li][li]after the pump operates for approximately once minute, I check the oil level[/li][/ol]
Now, the problems:
[ol]
[li]the pump does work, but it’s quite noisy, like a boiling kettle with not enough water [/li][li]the oil level has come down quite a lot, like if it’s consuming too much oil[/li][li]quite a lot of smoke/vapor comes out of the exhaust fitting[/li][/ol]
So, any advice? does it sound OK? anything that I should change?
Thanks in advance!
