I never did one but they asked me if I could build it. I’m always up for a challenge
It took me a while to think this through but here is how I did it.
The mold was in bad shape. I had to repair it and make a few changes to the flanges.
It’s for a RALT RT-40 Formula Atlantic
First I ordered some 3/8” aluminum honeycomb from Texas Almet and I made the mistake of choosing a little too stiff stuff so I had to cut it into sections and vacuum bag form it to shape.
Then I sprayed it with white Duratec gel-coat and using PTM&W 2050 (I love that stuff) laid up 1 ply 2x2 C/F. I did not want to draw vacuum thru the flanges with multiple cures.  After that was cured I bonded in the sections of honeycomb with 1 ply 2x2 C/F , 1 ply crowfoot Kevlar, 1 ply 2x2 C/F.  Potted in core splices and end features and wing attach pieces (alum tube bolt spacers at bottom)
The top plies 2 ea. 2x2 C/F, rear bulkhead 4 plies plain weave & it popped right out of the tool
After the pic’s I wet sanded it and buffed it (the car is white)
     awesome work. Are you cooking in an oven? What adhesive did you use to print the core? I always have trouble getting cores to lay just right? Even 3/8 nomex would have given a good fight in those radiuses. Also I see no trace of the carbon falling into the cells. What was your method? Is that a working transducer? Are you adjusting vacuum after gas out? Honeycomb can be a devil I’m trying to figure what approach you took in achieving such a smooth inside surface… Unless you potted and skim coated for that.
