Hi all,
New to the forum and composite construction. So far, I’ve made a flat square sheet and two 3/8" x 3/4" hollow rectangular tubes. None of these parts were really good, they all have flaws, but they were useful. I made what I wanted and learned a lot about composites. All work thus far was hand lay up.
The flat plate was made between 2 pieces of glass, with a weight on top. The first rectangular tube was wrapped around an aluminium bar and left cure on a piece of glass. I failed to remove the aluminium bar. My second rectangular tube was formed over a styrofoam blank. When cured, I used acetone to remove the foam.
In a couple of days from now, I’m going to attempt the layup over an aluminium bar again. This time I will be using vacuum and I think I’ve studied up on it enough to pull this off, but I’d like advice on it…
I plan to sand the aluminium bar up to 1000 grit paper, clean it, wax it with partall #2 paste and polish, repeating a 5 times. (this is where I think I failed before) Then using a coverall film mold release on the bar. Wrap the bar with the carbon fiber as I wet it down. Wrap perforated peel ply around that, then some breather material over top. I have 18" wide vinyl vacuum bag that I will place the lay up in, with breather material running from the hose to the part’s breather material. Then turn on the vacuum pump.
That’s what I plan to do, but would like any advice that might help me.
Would packing tape over the bar be easier than wax/polish/mold release?
Thanks for any tips,
Randy
