Nida-core Matline
http://www.noahsmarine.com/itemdesc.asp?ic=MATLINE301
Any advice/tips or feedback regarding this product? It sounds very similar to the coremat material.
Would it be suitable for epoxy ?
Do these core materials just wet out on the surface and through the perforations or do they get pretty saturated the whole thickness?
Thanks.
Yeh that’s exactly the same as coremat. They are a non-woven polyester filled with microspheres, and the microspheres are closed cell so they won’t absorb resin. However the polyester fibre still does absorb resin, and quite a bit of it. So they do end up pretty saturated, but less so than a solid laminate of the same thickness.
