First off, forgive me if these questions are answered in some blatantly obvious location I’ve been doing alot of research but so far keeping up with 3 boards worth of information is difficult.
I’ve been wanted to learn how to lay glass and CF/Kevlar for a while now so I’ve decided to take the plunge over spring break. My first project will just be a flat piece of CF to get the feel for it after that I was planning on doing an Overlay for my TI-86 cover. Pics of it can be found here:
http://wongablog.co.uk/wb-images/ti86.jpg
and here:
http://education.ti.com/images/products/accessory/translucent/colors/bluecalc.jpg
The case has a soft 90 degree curve around three edges with very rounded corners. The plan is sand the area’s with the rubber “feet” down after removing the rubber pieces (they fall off all the time). After that use some sort of filler to fill in the logo area then sand to a level finish.
This is where a question arises, there is lots of info on laying CF but I haven’t found a clear explanation on how you would handle those rounded corners with the cloth while maintaining continuity, also when you come to the edge of whatever you are laying over do you just resin it then cut and finish it down in the end or is there a way to wrap it? Basically how do you make the edges look nice and clean without hiding them.
Finally, just want to make sure my shopping list is accurate:
Standard protective gear(glasses, gloves, mask)
Acetone
Brushes for resin(1/2" or 1")
Roller (not sure what size, probably fairly small)
Resin(or glass)
CF (or Kevlar, or Glass Fabric, or whatever else)
Disposable stuff to measure out resin and the like/stir it
Body Filler of some type(have to research if there are different types/which way to go)
Not planning on working with molds quite yet so I’m not worrying about the chemicals necessary for it. Most questions have been asked and answered but I guess I couldn’t find the right search terms for dealing with rounded curves like that or similiar situations where you need the fabric to move in a way it doesn’t want it.
