I’m trying to wrap my head around the simplest “real” composite structure I can think of, the bane of physic and engineering students the world over - The I-Beam. And am I completely befuddled. I can’t tell if I made a math error, a formula error, or if I am trying to apply the rules of football to a baseball game.
Base material: A&P’s QISO Light, .28mm thick/ply, 272gm/m^2, Long Tensile 800MPa, Modulus 47GPa, Transverse 800 MPa, 44 GPa. Resin ignorable.
100 mm wide, 100 mm tall, 1 meter long I-Beam. 2 layers of fabric (web and flange)
a=.56mm, b=100mm, H=100mm, h=98.88mm, L=1000mm.
Total fabric area: 2 plies of .1m1m, 2 plies of .2m1m = .6m^2, or 163.2 grams
Load conditions: Cantilevered beam, unsupported end load, (A) 1000N, (B)1N
Moment of Inertia: Ix = (ah^3/12) + (b/12)(H^3-h^3) = (.0056*.001)/12+(.00416*(.001-.00000097) = .001457 = Call it .0015m^4 for simplicity.
Load(A) = 1000N*1 meter = 1000Nm
Load(B) = 1N * 1 meter = 1Nm
Bending Moment (A) = My/I (using Ix as I)= (1000Nm*.05m)/.0015m^4 = 33333.3 Pa, or .033MPa
Bending Moment (B) = My/I (using Ix as I) = (1Nm*.05m)/.0015m^4=666.7Pa or .000667Mpa
And here is where I get stumped:
Deflection of a end-loaded cantilevered beam: FL^3/3EI
(Case A): (1000N * 1m )^3/3(47GPa*.0015m^4)= 4.2728 meters
(Case B): (1Nm)/3(47GPa*.0015m^4)= 4.72E-9 (uhh… nano-meters?)
If my math is right, this beam fails catastrophically long before 1000N and completely ignores a load of 1N. Am I completely lost?
Thank you,
Clueless
Edit: Or should I be using MPa instead of GPa for deflection?
